ian dean
Member Since 18 Feb 2013
Offline Last Active May 12 2013 06:15 PM
In Topic: Unknown Part
12 May 2013 - 06:16 PM
okay thanks very much appreciated ill check it out tomorow when the weather is not as bad
12 May 2013 - 05:55 PM
it looks like a 10mm hose/pipe would fit in it.
12 May 2013 - 02:04 PM
i tried to mate but i have been back there and they no longer operate and the mobile number is constantly turned off
In Topic: Torque Settings
01 March 2013 - 05:57 PM
hi sorry about all the questions i was just wondering is it possible to remove the crankshaft and drop the pistobs out the bottom of the block or could i just undo thr pistons from the shaft and take them out through the top many thanks
01 March 2013 - 12:30 AM
thank you i have new bolts to go in. Im going to attempt to change the piston rings tomorow then i can put the head back on
