RichDartmoor
Member Since 22 Feb 2013
Offline Last Active Feb 23 2013 10:59 AM
In Topic: Focus 2003 Rear Brake Light Problem.
23 February 2013 - 10:54 AM
I had the same on my old mk1 the holder looked fine but i replaced it with one from a scrappy and that solved the issue if all else fails
artscot79, scrappy a good idea if all other routes fail, thanks for the post. Rich.
23 February 2013 - 10:53 AM
The brake lights are fed from one fuse -F54 (15A) in the glove box panel so you're best off checking the bulb holder for corrosion and the wiring for breaks and shorting.
Stoney871, thank you for your post, indeed I'll have a root around and see what gives. Rich.
22 February 2013 - 12:30 PM
Thanks for your post stef123, I'll certainly try the fuse and see if I can resolve the problem. Rich.
