Member Since 24 Feb 2013
Offline Last Active Mar 13 2013 01:12 PM
In Topic: Mk2 Facelift - Retrofitting Bi Xenon Headlights
01 March 2013 - 10:20 AM
Yup after a bit of investigation I have found that the motors in the xenons are 2 phase stepper motors which explains the 4 wires and the motors in the Halogens are servo motors so only 3 wires.
So as my car doesn't have the wiring for the stepper motors then its either make a driving circuit board to run the stepper motors or get some manual type servo motors and fit them into the xenon headlights.
So Haz do you have a set of manual motors for sale??
24 February 2013 - 09:15 PM
Im having ago at fitting Xenon headlights to my Focus CC. Iv'e got the Xenon lamps to light and Im now trying to work out what I need to do to make the leveling motors to work.
Does anyone know what signals/voltages the motors need to function and what pins on the headlamp connector they are feed into?
With a bit of elimination I think pin 7 is (-ve) ground, pin 10 is (+ve) 12v but I can't work out what the other two pins, pins 5 & 9 require.
Strangely I found that pin 5 is low resistance (0.6 ohms) to pin 7 and pin 9 is low resistance (0.6 ohms) to pin 10??
On the halogen headlamps pin 7 is -ve, pin 9 is the signal (0.6v to 12v) from the thumb wheel dash adjuster and the +ve for the motor comes from pin 2 inside the headlamp.
If I can find out what the motors need to move then it should be possible to make a circuit to do it manually.
Any help would be greatfully received.
