Gaz RS
Member Since 28 Feb 2013
Offline Last Active Yesterday, 09:00 PM
In Topic: Samsung S4 And 60 Plate Fiesta Problem
27 September 2014 - 09:31 AM
On you S4, go into your contacts, press the bottom left touch button to bring up the menu then select contacts to display. I have all contacts selected, that should display contacts stored on both sim and the device.
In Topic: Focus Mk2.5 Armrest Ipod Holder
23 September 2014 - 02:25 PM
You need to remove the back of the armrest then cut some holes for the securing tabs usb and AUX ports on the ipod holder to go through, there's a faint line molded into the plastic
Attached File  6.jpg   178.94KB   57 downloads
Attached File  7 copy.jpg   186.97KB   58 downloads
In Topic: Google Maps/navigation
18 September 2014 - 08:41 AM
I use Rocket Player to do this in my RS with the sony dab head unit https://play.google....therMusicPlayer It only works whilst streaming music from your phone though.
If you try it you may need to go into settings, audio, audio focus, temp focus action and make sure DUCK or Pause is enabled. If one doesn't work try the other.
Another app that works is shuttle music player https://play.google....er.music.player
In Topic: Mk2.5 Retrofit Bluetooth / Usb /voice
09 July 2014 - 08:26 AM
The module I used has part number CS7T-14D212-AD (AA, AB and AC suffix are also suitable). These modules are originally installed on the following vehicles:
*Focus MK3
*C-max MK2 and Grand C-max
*Kuga MK2
*Fiesta MK7.5
*Mondeo MK4.5 and S-max/Galaxy
This type of module can be configured for the Focus MK2.5, C-max MK1.5 and Kuga MK1 using a modified ELM327 interface and the ELMconfig software.
Hi Wilco, would you mind giving me the settings used in ELMconfig please.
In Topic: Fiesta Mk6.5 And 6000Cd Somehow Gained Bluetooth
28 June 2014 - 09:44 PM
It may be that you car has had bluetooth/ voice control all along but was not working, depending on the work the garage carried out they may have disconected the battery and as a result reset the  BVC module. Have you tried  any voice commands or paired your phone?
