wase16ll
Member Since 28 Feb 2013
Offline Last Active Today, 01:23 AM
In Topic: Granada Scorpiocan Any Of You Help.i Have A Granada Scorpio 91 V6 2.9I Auto.....
Yesterday, 10:02 PM
post is a bit confusing...
if i understand it correctly, runs perfect, come out following morning, wont start....after loads of 'fiddling' , it starts and runs fine.
so what were you 'fiddling' with to make it start....was the engine turning over fine but not firing or sounding like a low/flat battery?
then you mention alarm and no response???
does that mean engine wasnt turning over?
not sure what you mean by ticking noise when opening the door, unless you mean the chime
then go on to say about adjusting s.plugs..
so when you adjusted the plugs, engine then turned over and started but ran rough, then ok then rough....
so, are you still having starting problems or is it now starting but running rough?
In Topic: Speedo Drop To Zero, Engine Man Light, Battery Light And Fuel Light Came On.....
Yesterday, 08:48 PM
i would look for a fault in the power supply system...battery/connections/earth leads etc
In Topic: Streetka Trouble Starting
20 May 2013 - 01:40 AM
could be coil pack....said it improved after plugs/leads, so could be related,
often found with fords that if there is ever a problem with any of the plugs or leads or coil, you end up having to change the whole lot..
but could still be a fueling problem if its noticably worse in warmer weather...coolant temp sensor or a faulty injector maybe
In Topic: What Car Inspires You...
18 May 2013 - 09:10 PM
Postman pats Van
Dont believe me wait till ive finished the paintwork!! LOL
Steelie
you reminded me of this from years back...always brought a smile to my face when i come across it
Attached File  Mini smokin it.jpg   25.57K   1 downloads
18 May 2013 - 08:19 PM
:D
i used to be into pure customs, so never got into lowering etc etc standard cars...
dont have the time to get into either now, so bog standard boring is the way for me now
