Petel
Member Since 03 Mar 2013
Offline Last Active Oct 18 2014 10:38 AM
In Topic: Demist Question Please.
08 October 2014 - 09:20 PM
Thank you again DP
08 October 2014 - 01:19 PM
Thank you DP.   Can you please advise,
1, If I reach in and hold the valves motor body, will I be able to feel the motor working when the valve is cycled?
2, Does the fact that the motor runs confirm that the valve is opening and closing?
3, Can I take it that the valve is the only motorized item and that all the flaps in the heater unit are
    cable operated?
Thank you
29 September 2014 - 03:37 PM
Thank you for your reply.
                               As stated, she is complaining that she cannot get enough heat blowing up the inside of the screen. How much or how little heat is coming from the system I have no idea.
Are you aware of any type of adjuster in the heater system please?
Thank you.  Pete.
