Member Since 05 Mar 2013
Offline Last Active Mar 05 2013 07:39 PM
Mk Iv Rear Brake Overheating Issue
05 March 2013 - 07:28 PM
Hi all,
Bought a 2010 2.0 litre diesel Zetec Saloon last November.  I thought that the car would last until the next service, due this August.  How wrong could I be.
It seem like both pads got a bit low on both rear brakes and both calipers seized on because the slide pins were bent.
I have replaced these pins, wound back the caliper pistons, fitted new discs and pads but there is still a problem.  The discs are getting hot on a 20 mile drive.
I have checked the handbrake cable and the lever on the caliper is free to move back approximately 1-2mm from the back stop.  With the car jacked up, the wheel spins freely when the handbrake is not on although you can slightly hear the pad on the discs and when the hand brake is applied the wheel is locked as expected.
At the moment, everything is pointing to an issue inside the caliper, probably with the internal hand brake mech not returning fully.  But because it is almost operating fully, I am not 100% sure that this is the full extent of the issue.
Is it time for a caliper strip down?  Or could this be the non-ford pads and dics?
Any Ideas?
