Member Since 06 Mar 2013
Offline Last Active Dec 11 2014 03:26 PM
Mondeo Mk4 1.8 Tdci Coolant Leak By Thermostat
06 October 2014 - 07:05 AM
Hi everyone, i drive a 58 plate mondeo 1.8 tdci and i noticed a leak by the thermostat housing so i emptied the cooling system and undid the 3 screws holding the housing and then i removed the thermostat wich had a seal around it. I replaced that seal with a new genuine one, cleaned that area and put everything back but now is still leaking. Did anyoane experienced this before? I am thinking now to change the housing or the thermostat. At this moment the cooling system is working fine, except the leak. Or is a good ideea to use some appropiate sillicone for this job when i put the housing back to create a seal, would that work?
