Member Since 07 Mar 2013
Offline Last Active Nov 23 2014 10:57 PM
Focus Titanium 2012
23 November 2014 - 06:46 PM
Hi, has anyone ever had cause to see the warning for a low tyre pressure?
I went over a pothole today and discovered about an hour later that my front near side was flat.
I hadn't noticed before I got in the car but obviously did when I started to drive off and immediately stopped.
A trip to the tyre place near me tomorrow after inflating the tyre, which I had done and seems to be holding.
I had no warning of this as I started to drive, just wondered if anyone has seen it work?
I always reset it after ever inflating the tyres.
Many thanks.
Sync: Iphone Texting Problem.
11 November 2014 - 05:59 PM
Just had my Focus Titanium serviced and mentioned the problem of not receiving notification of who is sending a text (as per the advert) as well as the fact that you can only receive a text if the phone is locked.
Apparently this is something Ford are aware of and I was given a document explaining how this is rectified. This document only shows you how to unsync and ensure you check settings whilst sync is disconnected.
Done all that repaired the phone and nothing has changed.
The garage said that this fault was to do with the release of ios8 but I have had the same problem since having the car from new two years ago.
Presumably there is no cure to this problem but thought I would post in case anyone else has experienced this problem and, of course, if anyone has a fix.
I'd be interested to know if anyone has iPhone on ios 8 (or 8.1) and it works OR, if anyone has ANY mobile phone that does work correctly with Sync.
I'll now email Apple to see what they have to say.
Many thanks for listening.
Focus Titanium
22 February 2014 - 09:49 PM
Had to have my windscreen replaced recently and immediately discovered (after the fitter had gone) that one of the wipers had not been replaced properly. This had to be rest by a Ford garage (under warranty) after the fitter had returned and thought he'd rectified it. A few days later I get a warning message saying the screen needed cleaning (it didn't) and my lane keeping aid was faulty. It's booked in (again) to have this looked at and to obtain a quote to try and claim against the windscreen company. I now find that I have also lost the use of auto headlight dipping and speed limit recognition. I say all this to make sure you check out any sensors/cameras are working (if you have them) after having a new windscreen fitted.
