Member Since 08 Mar 2013
Offline Last Active Mar 08 2013 08:54 PM
Problems With Egr Valve
08 March 2013 - 03:38 PM
Hi all
I have a 2007 (On a 06 plate tho) 2.2lt TDCi mondeo estate with a duratek engine,
I've owned the car for just over 2 years and am about to replace the EGR valve for the second time. I have been told that this is a common fault and these valves only seem to last 18 months to 2 years at a time.....
Its been code read and the only error is this valve and last time we changed it, the car ran like a dream until recently when it started refusing to start and then chucking huge clouds of smoke out when it eventually did or losing all power when driving, especially when pulling away. Had the valve cleaned out a number of times to keep it running for as long as possible as the new valve is not cheap but finally had enough and am having it changed again!!
Is there really a common fault with this year and EGR valves or could there be a problem else where in the engine causing this valve to brakedown and is there anything that can be done to stop it happening??
Thanks in advance
