Member Since 09 Mar 2013
Offline Last Active Today, 09:02 AM
In Topic: Strange Noise When Cornering
09 September 2015 - 08:55 PM
Tyre pressures are fine. The ESP light on the dash isn't flashing, I know what it looks like as the one in my Transit spends a lot of time flashing when it is being driven briskly! Also I never hear it working in the Transit, just feel it. Front brakes on the Focus are under 12 months old, and tyres have around 4k on them.
Im not that worried, everything seems to be working fine, it just sounds a bit odd.
08 September 2015 - 09:01 PM
Thanks, It seems a bit strange that I've only recently started to hear it, as I have had the car for 2 years and not heard it before. At the speeds it is happening at, I'd be very surprised if ESP would even begin activating. Maybe the Contis aren't as grippy as I thought they were!
07 September 2015 - 07:34 PM
In Topic: Most Likely Damage To Sustain If Hit Speed Bump Too Fast?
08 August 2015 - 09:12 PM
36 front 26 rear, it tells you the pressures on a sticker on the passenger side B pillar.
I run about 35 all round on my Focus, too high a pressure can reduce grip, increase wear accross the middle of the tyre, and cause problems if you hit a bump or speed hump too fast, as there is no give in the tyre with that pressure. Ooops.... wait a minute......
In Topic: Cigerette Lighter Interferance
26 April 2015 - 02:44 PM
My Focus and my work Transit both do the same when I plug anything into the lighter socket.
