Endless Summer
Member Since 10 Mar 2013
Offline Last Active Jun 18 2013 01:54 PM
In Topic: Which Engine Is In My Mk3?!
19 April 2013 - 10:28 PM
Finally found the cause of the whistling noise. The hose on the inlet side of the inter-cooler was pantsed.
New hose, new clip. No whistle and boost issue resolved. I didn't realise how much power I was missing until afterwards. It drives like a new car.
In Topic: Help Needed Please.. I Want To Buy A Used Mondeo Estate!
22 March 2013 - 05:14 PM
IMO, buying off Ebay is asking for trouble unless it's quite cheap and you are prepared to sort through any problems!
Best to see any car in person, give it a detailed looking over physically, mechanically and a good drive, at least 30 minutes and boot it on the motorway.
If your not mechanically minded, pay someone to check it over.
My thoughts on the car you provided are: It's a black Mondeo, Ghia estate
22 March 2013 - 03:34 PM
What's the best way to remove the C clip on the Actuator arm?
21 March 2013 - 10:38 PM
I believe I've done the best visual and audio inspection I can on the turbo pipe system. Haven't been able to find any obvious leaks. New hose clips have gone onto the EGR/Intake hose, more due to the fact that the original hose clips were almost threaded.
I cleaned the MAF sensor with a cotton tip and carb cleaner. The central wire was clean with only the two horizontal wires having any visible carbon build up.
Did manage to find a small hose leading to from somewhere to the air intake on the other side of the MAF that was loose. The clip has simply come undone. Does anyone know what this pipe is for?
I've also been reading up about the turbo actuator arm on variable vane turbo's, which I believe I have. From what I understand, the arm should activate and move upon starting the engine. I removed the turbo heat shield and wasn't able to see any movement on the arm at all.
The vacuum hose did have a small slit where it was attached to the diaphragm, which I cleaned up by taking a  5mm off the hose. Confirmed that there is suction from the hose when engine running, but still no action on the actuator arm. I was considering trying to remove the small C clip that attaches to the arm and check the movement range but it was getting dark and to be honest I'm not sure how to remove it without it pinging off into the engine bay somewhere!
Should I be expecting to see movement on a vacuum operated arm, or have I got my "hoses crossed"!?
 Pic below of the area I am talking about.
The more I get into this motor, the more useless this Haynes manual becomes! So far the only assistance it has given is for torque setting............
18 March 2013 - 03:40 PM
That makes sense about the boost not sucking in then! There is no "whistle" until about 1600RPM and it continues while I accelerate. I can't hear anything upon changing gears, the whistle stops if not under acceleration.
Sounds like it will be tough to get to all the hoses without a jack and stands. I'll start hunting for a high curb to park up on so I can get to the hoses under the intercooler.
Plan of attack sounds like checking a leak on boost side hoses and maybe new hose clips!
Sorry for this thread turning into such a monster!
