Member Since 14 Mar 2013
Offline Last Active Oct 14 2013 09:12 PM
In Topic: 1.4 Tdci Charging Problem
14 October 2013 - 07:06 PM
I put the meter on it just now and it's reading 10.4 and dropping slowly while engine is running. The light has decided to come on now too
14 October 2013 - 06:34 PM
Forgot to mention it's an '02 mk6
In Topic: Lost Power To Cluster And Car Won't Start
31 August 2013 - 08:13 AM
Got to the bottom of this problem. Turns out one the 60 amp main fuses in the distribution block on the battery box was blown. It didn't blow for no reason so went investigating round where the loom goes behind the turret and through the bulk head. Turns out that the wiring had been rubbing off a bracket and the insulation had all but worn right through. It obviously shorted when I disturbed it and blew the fuse. Good job that it happened really as it could have easily let me down whilst driving. All fixed up now and working perfect
In Topic: Airbag Light Not Working (Fault Codes)
15 March 2013 - 12:27 AM
Ill scan it again tomorrow and see if there are any sub-codes. Thanks lads
In Topic: Hi!
14 March 2013 - 06:51 PM
Hi Davy welcome to the club mate. How you finding the modeo? And what problems are you needing to sort with it?
Just a few wee issues with airbag and an abs pressure transducer. I've started a topic about it. Actually loving how it drives. As I said its my first ever ford out of a lot of cars. It's the 115 bhp 5 speed and has plenty of go for daily use. Hoping it will be as good on fuel as my old passat was!!
