cliffy 71
Member Since 14 Mar 2013
Offline Last Active Mar 29 2013 06:07 PM
In Topic: Mondeo Problem Help !
27 March 2013 - 06:04 PM
Still no joy with this car, cylinder no 3 still off and smoking like hell, iv checked glow plugs, is there a way to test the injector or what should my next step be cheers
25 March 2013 - 09:01 PM
Oh yes a big warning ! When working on crank shaft sensor fill the hole in with some tissue etc , I dropped the bolt into the gear box and had to partially remove the box I was not happy !
25 March 2013 - 08:49 PM
Sorry the crank sensor goes as far down as it can . We had it about 3 mm from fully in and it wouldn't go .
25 March 2013 - 08:46 PM
But surely if it's smoking fuel is going into the cylinder but not igniting ? As for a compression test the engine ran perfect in the car it was taken out of. Could glow plug cause it
25 March 2013 - 07:40 PM
Hi all finally got it going where the garage failed ! It was the crank sensor was slightly too high . Now it is only running on 3 pots ( 2nd from timing belt off ) and smoking like hell I would welcome your thoughts on that and best way to test it thankyou.
