Member Since 15 Mar 2013
Offline Last Active Apr 09 2013 08:42 PM
In Topic: Zetec-S Exhaust Mod
25 March 2013 - 12:36 AM
You can't get a tip unless they make one that has like a u-bend in it. Never seen it though. I had the same problem with first Fiesta (57 plate) I had to go and get a back box professionally fitted. It cost £130 so it's more than what a tip would cost but well worth it as you get the sporty noise to go with looks. Depending on the style you get it can also come under Neath the bumper (I didn't want to cut through the bumper, when I sold the car I removed the backbox and put the standard one back in).
Hope this helps
Believe this was you? Is this not an option then? Sounds perfect for my situation if true?
24 March 2013 - 10:59 PM
As much as a good idea it sounds it's often not worth it :( you'd also have to inform your insurance company who would easily add an extra £400 for those mods
Yh, think il just leave it or buy a trim to get the exhaust On show at least
24 March 2013 - 10:38 PM
Ford will charge you however much it costs to return the car to standard and in a sellable condition
Any guesstimates how much that could be?
24 March 2013 - 10:29 PM
Probably best spending a few hundred on a good exhaust system if honest.
Only problem is the car would be in ford options therefor probably given back at the end of it
Would ford do this? Or a company where ford warranty wouldn't be void?
In Topic: Exhaust On Zetec-S
23 March 2013 - 07:13 PM
That sounds affordable then.
I was only worried that exhaust systems on the Internet can cost £300 then add fitting costs but that sounds affordable
Thanks for the answer :)
