s90jny
Member Since 16 Mar 2013
Offline Last Active Aug 27 2014 03:07 PM
In Topic: Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
24 March 2013 - 08:20 AM
Thanks Wilko, I own the MK1 Focus CMAX. I have been helping a few friends with a MK2 Focus.
Bobby... have you managed ot make any progress?
Yes disconnecting the battery solved half the issue. I then had to reset 2 fault codes before the kuga would start. thanks for the help
23 March 2013 - 01:52 PM
gotya
23 March 2013 - 01:42 PM
Disconnect the positive lead from battery and hold it to the negative pole for a bout  5 minutes to totally discharge all residual current.........reconnect and hopefully should restart.
is this not dodgy to do?
23 March 2013 - 12:01 PM
Was you using bluetooth ?
Have you tried connecting , then selecting procedures and reseting the module
Did you do the number one Golden rule and Backup ? , if you did try reloading the backup and writing
no i wasnt using the bluetooth.
i have tried all methods available - under the hec tab it says no data(like it does with the ignition off)
yes i have back up..... but they cant be written to it due to the no data warning
23 March 2013 - 11:35 AM
More detail  , what did you update onthe Kuga , did you do backups , what have you tried etc.
i update the dash rom(no issues) i added eco and shift light (no issues) on the hec tab i was on tab 3 (the 1 that has the warning about not connecting via bluetooth) when i pressed read it all failed and wont come up.
