Captaintess
Member Since 19 Mar 2013
Offline Last Active Sep 24 2013 08:33 AM
In Topic: Ford Focus Brake Master Servo
17 August 2013 - 08:45 PM
hi, the pressure was tested via the vacuum pump as well as the vacuum hose take off, it is a diesel.
the method used was a vacuum tester that connects to the hose and pump.
the recommended pressure is 500mm HG and my pump is chucking out 600mm HG, so by rights this is working.
Kind regards
In Topic: Ford Focus Ghia 1.8Tdci
17 August 2013 - 11:56 AM
ok, no problem. good luck finding a cheap engine for that then, let me know how you get on, kind regards
17 August 2013 - 11:22 AM
360672355215, try this ebay number, it's it Maidstone, but they will carry it for yah! about £50.
Kind regards
17 August 2013 - 11:17 AM
Shame as i've just scrapped a decent bottom end... still you don't really want to know that! you could shop around however getting it delivered is a pain!
Can you not re-furb yours?
17 August 2013 - 10:17 AM
Hi, you can get a half decent engine from E-Bay, i got one for £250, albeit did not come with all of the injectors/turbo etc, however you could use yours.
Where abouts are you?
Kind regards
