Member Since 19 Mar 2013
Offline Last Active Apr 01 2013 08:19 AM
In Topic: Mondeo Tdci 130 Zetec S
31 March 2013 - 07:56 PM
Just a quick update had the car running started it with easy start then throttled it and it kept running on its own diesel wahoo but once stopped throttling it just died then to start again had to use easy start then would run on its own diesel again till let throttle off any ideas would be appreciated also was smoking white smoke
29 March 2013 - 11:59 AM
hi i have fuel pressure at the rail when cranking its like the injectors aint firing just wondered if there could be anything else that could stop them.
28 March 2013 - 05:04 PM
Had cover off and timing is fine changed both cam and crank sensor but still no joy anything else it could be cheers Chris
25 March 2013 - 11:41 AM
Hi injectors were coded in firing order and from the injectors themselves for the codes
I am going to take timing cover back off and double check that
Just seems strange that it will start on ether but nothing else
23 March 2013 - 06:17 PM
Checked both sensors and both are ok
Everything says it should fire
Injectors and firing
Rpm 235
Pressure 410 bar
All injectors coded
But still don't fire
Compression is ok
Any ideas would help please
