Member Since 19 Mar 2013
Offline Last Active Apr 01 2013 08:19 AM
Mondeo Tdci 130 Zetec S
19 March 2013 - 07:55 PM
just after picking some brains out there i have a 2004 zetec s tdci which the cam chain had jumped on it so i have replaced this along with all the sprockets and tensioners like you do put it all back together timed up spot on with all the correct pins and links in right place but does not run still
engine cranks over at around 230-240 rpm
fuel pressure is roughly around 330000kpa
will start and run on the dreaded easy start but soon as you stop spraying just cuts out again.
done leak back test all is fine on that front
high pressure pump is all ok
