ChrisH
Member Since 15 Feb 2009
Offline Last Active Jun 21 2015 09:09 PM
In Topic: Smell In Car
14 May 2015 - 08:23 PM
I had this on my Focus diesel.  It ended up being leakly injector seals and leak off pipes, leaking fuel onto the manifold.  If its a diesel, hold you hand aboe each injector. If its leaky you should feel a puff of air onto the palm of your hand, on each injector cycle
In Topic: Any Ideas What This Is???
14 May 2015 - 08:20 PM
Climate sensor is on the front of the dash.  Maybe its a little speaker, but it seems a bit pathetic.....
14 May 2015 - 08:19 PM
Yeah, I thought that too, photos not clear,  It points more toward the driver.  There is not one on the passenger side, and no matter what the airflow is set to, no air comes out.  The car has auto climate control, but even set to manual, nothing comes out of it.
In Topic: Tyre Deflation Warning.
14 May 2015 - 08:08 PM
Thanks Jeebo.  No codes at all, and it seems to have settled.  Maybe it was the new tyre settling in??
08 May 2015 - 09:39 PM
Thanks. Had the car since December. Never seen this issue until I got this nail in a rear tyre. Since I reset last friday, not seen since. How do I check for codes in the new cmax. Is there a way like on the focus. Can it still be done with the power start button. I presume you agree with the premise that the fan is the dpf regeneration. I am surprised at that as the car is predominantly used for motorway runs.
