laurashgeo
Member Since 25 Mar 2013
Offline Last Active Apr 14 2014 06:55 PM
In Topic: Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
03 April 2014 - 10:08 AM
Next to the shifting behaviour of the automatic gearbox the automatic transmission settings also affects the throttle response of the engine.
On the Focus MK2/MK2.5 the throttle pedal is connected directly to the instrument cluster. The instrument cluster converts the resistance signal of the throttle pedal to a CANbus signal which is distributed to the PCM. Depending on the selected settings the instrument cluster softwarematically changes the throttle response.
On a manual shifted car the automatic transmission settings does also affect the throttle response. Changing the automatic gearbox settings on a manual shifted car is a known trick to make the car feel a little more powerfull.
Can you, please tell me more about "hanging the automatic gearbox settings on a manual shifted car is a known trick to make the car feel a little more powerfull.
20 April 2013 - 11:54 AM
I fallowed the tutorial from the first page. Than I saw that there are double switcher on the market.
20 April 2013 - 11:06 AM
I received the second diagnosis and it is working :D
I manage to add the switchers and I now I have Eco Mode, DDS, Radio and Auto-locking.
I will put some photos to see that the interior is completely different to the the one from the tutorial: the leds are smd and the pins are in another order.
I activated also the double locking, but is not working!
