Member Since 25 Mar 2013
Offline Last Active Apr 30 2013 06:11 PM
O/d Flashing On Dash On 56 Plate Mk3 Auto
23 April 2013 - 08:39 PM
hi, fuel problem now solved, fitted new pump and now o/d  flashing on my automatic 56 plate, gear change slow and erratic, any ideas what this means?? Thanks
Code P0232, Voltage High,secondry Fuel Sensor. Help!!!!
10 April 2013 - 11:47 AM
hi, my 56 plate mondeo 2.0 auto is not starting, checked the fuel pump and it had no voltage reading so replaced the fuel pump relay switch and after a couple of turns she did start, the next day nothing, guy came with a scanner and the code p0232 flared up, the secondry fuel sensor voltage is too high, any tips would be great..
Heaters Only Blowing Cold Air
29 March 2013 - 11:02 AM
hi, my 05 streetka has now starting blowing cold air from heaters, had her running for 20 minutes and put on hot but nothing, plenty of water and head gasket seems fine,,water does look a little dirty though,,any ideas or assistance would be great :)
Streetka Windows Not Working And Roof Hatch At Rear Not Opening
25 March 2013 - 10:01 PM
hello, looking for some help, my 05 reg streetka windows have stopped working and i have lately also noticed that the roof hatch at back is not opening when i press the button on the side.. are these connected or two seperate faults?? windows stopped working a few days ago and only tried the roof hatch button the other the day and there is nothing.. any help would be great..  :)
