Member Since 27 Mar 2013
Offline Last Active Feb 03 2014 03:37 PM
In Topic: Heater Matrix Removal Mk6 Fiesta
03 February 2014 - 03:31 PM
Its worth double checking that it is the matrix before doing this as it turns out i was wrongly diagnosed with my car and its not very often the heater matrix really goes. mine turned out to be the rubber pipes in the engine bay where they connect to the matrix had split with catching on other components. saved me a lot of time.
In Topic: Dashboard 2003 Fusion
03 February 2014 - 03:27 PM
Mine was doing the same, it was a combination of the centre cubby box and speedo casing, for the speedo casing i got some black rubber edging strip off my kit car, removed the speedo cluster which just pulls off, edged it and put it back on, cured most of the noise.
In Topic: Please Help! Ford Fusion 2003
03 April 2013 - 03:52 PM
My gut instinct is its an electrical problem near the glow plug relay but could possibly be a fueling issue as it starts with a foot on the throttle and sounds a bit grumbly afterwards. Further inspection i think when i get a day off, groan!!
28 March 2013 - 02:05 AM
Hi Guys,
Was this guide helpful in removing the matrix? i have a fusion tdci so am assuming its the same 'ish' process.
Many thanks
28 March 2013 - 01:10 AM
Hi Guys,
Just wondered if anything got sorted with this as my fusion tdci seems to do the same, turn the key it turns over then stops, only when the car has sat for a while. I've had it fault checked but no problems showed up, could it be a control box somewhere telling the car not to start. It is very weird.
P.S new to the forum so hi everyone!
