Member Since 04 Feb 2008
Offline Last Active Oct 10 2009 08:12 PM
In Topic: Wear and tear at what miles does.....
10 October 2009 - 08:12 PM
My cabby had 60 k on the clock when I had her, it has recaros in it and the seat had started to split when I had it. I am only slight and even I rubbed up against it getting in and out. I suppose it depends on what seats are in it, where abouts you sit ETC. Hope this helps
In Topic: It's Official...
10 October 2009 - 08:05 PM
You lot want to thank your lucky stars that its just spiders that you have they are really not that messey. i have new neighbours with pigeons, now thats messey!!
In Topic: Lop sided
04 October 2009 - 05:47 PM
It hasnt been in an accident has it???
In Topic: mignulikz - Spamming PM inbox ***WARNING***
07 April 2009 - 08:02 PM
I also received an email but couldnt access it. What a c**k
In Topic: escort diesel - non starter
10 March 2009 - 08:43 PM
Have you changed the fuel pump or has it come off the engine that you have put it? Have you tried loosening the injectors to see how much fuel is coming through? If its got a different fuel pump you wont get the immobiliser to turn off. Have you used the manual pump to pump out the system of any air.
You could also try towing the car to see if it will start.
Sorry if you have tried all the above, but having recently done a engine on a pug we were stumped like you are when it would turn over but wouldnt run. We put the original fuel pump off the engine back on and hey presto much joy.
