Member Since 30 Mar 2013
Offline Last Active Apr 02 2013 09:33 PM
In Topic: Streaky/blank Central Display
02 April 2013 - 09:34 PM
Thanks for the above. I have Autoguard warranty (supplied when I bought it for 1 year) but wouldn't mind having a go myself if it's relatively easy because if it's just a bad connector/dry joint on pcb I'd rather try and resolder than use up what would probably be a few hundred pounds worth of replacement work.
However a (non-Ford) garage told me the dash panel can be coded and may fail to work if removed and replaced. Can I assume he was being over-cautious and that this isn't the case?
30 March 2013 - 08:25 PM
Sounds like the dash needs to come off.
Sorry to sound ignorant but where do I go to find out how to do that? Is there a good aftermarket service manual?
