Member Since 05 Apr 2013
Offline Last Active Nov 08 2013 06:37 PM
In Topic: Turbo Not Pulling Focus Tddi
02 May 2013 - 06:57 PM
this what i used on all the joints etc
02 May 2013 - 06:56 PM
i had a similar problem with my 1.6 tdci..checked the engine bay and found that the air inlet pipe had a crack in it..changed this but still the same...so i went around all the jubilee clips and found that all of them were loose..so tightened all these..then as a secondary measure i put self augmenting tape around all the joins...blimey..what a difference..she goes like poo off a shovel now...using less fuel and pulls like a good un...worked for me..maybe worth looking at all the joints and clips etc...
In Topic: Heater Climate Control Switch Knobs
01 May 2013 - 05:55 PM
roll on pay day....
In Topic: Intermittent Rumbling Noise
21 April 2013 - 06:00 PM
after checking all the pipes etc..i found that a lot of jubilee clips were loose..so after tightening them all up the noise has gone...
16 April 2013 - 05:40 PM
after listening to this noise carefully now, its sounds like a dump valve. esp in 1st the revs hit around 2000 and there's a loud 'psssssst' noise.
i changed the air intake pipe as the little pipe leading of that was cracked, but now i don't where else to look. it doesn't affect the performance of the car as its still quite nippy..i have a 07 1.6 tdci...any suggestions would be great ..and yes you may have to draw pictures..thanks
