Member Since 07 Apr 2013
Offline Last Active Apr 01 2015 06:20 PM
Mondeo Problem
01 April 2015 - 01:04 PM
Hi people.
I have a 55 reg 115 2l mondeo which had a fault coming back as P0203 - Cylinder 3 Injector Circuit Malfunction.
so we did a leak back test and it poring out with  diesel. my brother then took it out straight away without
starting it and took the injector apart and cleaned it up.  he then put the injector back and now its just cranking over and over
with a fault of low fuel pressure when cranking. but it did run before he took apart.  we had another injector which allowed the engine run before
he did above, So put the injector back and coded it back in, and  try and it is still coming up with low fuel pressure.
Any ideas would be great
Ps on the diagnostic it is showing a bar of 17 when cranking.
