Member Since 17 Feb 2009
Offline Last Active Mar 12 2009 10:22 PM
In Topic: Stiff gear change
06 March 2009 - 09:01 PM
the gear selection will get better as the oil warms up, first thing would be to check the oil level and even think about a oil change. also check the linkage for any missalignment.
Thanks I'll change the oil and see If It helps.
In Topic: Noise behind headlights on a mk 2
24 February 2009 - 10:58 AM
Thanks SY99, It was the motor, although the headlights are stationary the motor keeps making a noise I found If I keep adjusting the height I can find a position where the motor stops making the noise. Luckily the height It's quiet at Is OK so It will do till I can look at It properly........Thanks.
