Member Since 21 Apr 2013
Offline Last Active May 06 2013 07:00 AM
#257796 Mk6 Fog Light Inserts
Posted by JamesEmbling on 05 May 2013 - 07:46 AM
Unfortunately mate your stuck with the second set, the first set lean in a different direction to the others so wont fit.
#256738 Humming From Front Wheel
Posted by JamesEmbling on 30 April 2013 - 09:05 PM
I had a similar problem on my fiesta and it was my wheel bearings, noise when turning around a right hand bend could indicate a problem in the passenger side bearing as the weight is shifted onto the left side
#256504 Oil Leak
Posted by JamesEmbling on 29 April 2013 - 09:56 PM
I see, if its only a small leak I wouldn't have thought its an emergency to get it done, I'd just say to keep an eye on oil levels maybe to ensure you don't run it dry and get it looked at when its convenient for you
