Member Since 28 Apr 2013
Offline Last Active Oct 27 2013 12:19 PM
In Topic: Interior Ambient Lighting
23 October 2013 - 09:00 AM
Which bit?
Don't matter mate I'm just going to retro fit some LEDs cheers
21 October 2013 - 09:45 AM
This is really odd because my ZS has all the Ambient lighting wiring, and i got the dealer to add the lights.
The glove box wire is just above the glovebox tucked in a proper blanking holder, the door card ambient wiring was a little more involved as that needed a loom made up and took 6 weeks for ford to make for me, and the wire for the lighting to come on and go off with the rest was easy to find.
The ambient light in front of gear stick in the centre console no longer exists for the mk7.5 models, so ford ordered a mk7 and i took a feed from the glovebox wire rather than splicing into this or cutting into that!!!
PLUS -  The ambient lights on all of them are really nice and bright!!!  I have noticed a number of ppl mention the glovebox one not being 'that' bright, but mine is.  I'm very pleased with it, and the door side ambient lights under the handles and in the door latches are great!!!  Looks awesome.... :D  :D
Hi there do you have pictures of how you did yours thanks
18 October 2013 - 06:02 AM
I retro fitted mine with LEDs and they are super bright, you can clearly see the LEDs in in direct sun light, also wired in a switch and relay so they come on when i open the car but turn off when the car starts but can work if i put the interior over head switch on toke some time and help wiring it but works a treat :) much better than factory fitted
Do you have a guide on how you did yours cheers
17 October 2013 - 08:32 PM
Cheers guys thinking of just selling these & fitting LEDs
17 October 2013 - 10:59 AM
Yeah mine is a 62 reg zs it the proper set of ambient lights that I have the connections are there for these just they don't come on is there an easier way to connect using the proper wires that's there or would it be easy to connect to side lights so they on when there on cheers
