RobK
Member Since 29 Apr 2013
Offline Last Active Feb 11 2014 05:58 PM
In Topic: Focus 2.0 Tdci Intermittent Starting Issue
11 February 2014 - 05:59 PM
Hi Sam
All diesel models should have this valve. Easiest thing is to look under the bonnet!
Rob
11 February 2014 - 04:51 PM
John - glad to hear this seems to have solved it for you, and happy to know it's not just me to have experienced it!
Naz - it's called an anti shudder valve. If you give it a quick search you'll find quite a lot about it, but more often related to VAG cars. There are pictures of location on the previous page, but it's not something you'd find on a petrol car though (unless I'm very much mistaken).
Rob
02 February 2014 - 09:31 PM
Hi John
Glad they helped.
As for the oil that's to be expected so nothing to worry about there.
Rob
01 February 2014 - 02:58 PM
Hi John
As promised some pictures to show the location. Hopefully in sequence they're quite easy to follow.
Attached File  photo 1.JPG   119.38KB   33 downloads Attached File  photo 2.JPG   111.52KB   30 downloads Attached File  photo 3.JPG   111.58KB   32 downloads Attached File  photo 4.JPG   102.03KB   32 downloads Attached File  photo 5.JPG   103.25KB   25 downloads
For full sized pics click here.
Good luck!
Rob
31 January 2014 - 10:27 PM
Hi John
It's too dark now, but I'll take a picture for you tomorrow as it seems like the easiest way to help identify it.
In very basic terms it will be the largest diameter hose (turbo hose) that comes up from the bottom of the engine to the front near the top.
If you loosen the clip at the top and slide the hose off then you should be able to reach the butterfly valve with your hand.
Try closing it by hand and seeing if it sticks at all or is particularly tight.
I also found that squeezing the turbo hose would sometimes be enough to release the valve if it was stuck. In this case listen carefully to see if you can hear it releasing. It should always be open apart from within a few moments of the engine stopping.
I never received an engine management light or fault though, so it's entirely possible you have a separate issue. Here's hoping it's simple!
Hope that helps for now!
Rob
