Member Since 30 Apr 2013
Offline Last Active Jul 23 2013 05:22 PM
#265038 Oil Leak Out Of Of Wishbone
Posted by Steelie600 on 03 June 2013 - 06:08 PM
yeah it should be fine. basically you have 3 pins sticking out from the end if the shaft. and 3 big wheels that sit on those pins. Those wheels rotate on roller bearings which are cylindrical. Basically clean it all up so its spot less.
Then fill a wheel with rollers and then shove some fresh grease in there and put it on the pin, do the same for the other two.
the fill the drive cup with the rest of the grease, and then sit cup on top of the rebuilt shaft assembly then using some cable ties fasten the boot back up and refit to the car.
#262482 Revs Hanging While Changing Gear?sensor?
Posted by Steelie600 on 24 May 2013 - 10:37 AM
Thats programmed into the ecu to hold the revs momentarily when changing gear. Apparently Ford cant trust us to change gear smoothly so they do it for us
#262043 Next Rs Model
Posted by Steelie600 on 22 May 2013 - 01:55 PM
the Escort is coming back in a few years to replace the Focus. New Escort Cossie anyone????..... Ill be first in the queue
#262042 Help! Drivebelt Change Gone Wrong
Posted by Steelie600 on 22 May 2013 - 01:52 PM
can you get a video??
Its a bit hard to diagnose without seeing it.
Yes trying the old tensioner might be an idea. Ive had one on a mk1 focus replaced the lot and it vibrated like mad so put the new pulley on the old tensioner = fixed LOL
#261797 Engine Rattling When Idle
Posted by Steelie600 on 21 May 2013 - 05:51 PM
If its not rattling when you switch off the DMF is fine. But I would still recommend a clutch while your in there.
Release bearings make this kind of noise, is noisy when no load on them but shut up when you depress the pedal. Im a technician with over 20 years experience and this is my bread and butter.
Parts for the clutch and bearing your only looking about £100-£150 from a parts factor. and to fit its a 6 hour job because the gearbox has to come off.
Dont be too dis-heartened its just generalwear and tear its not a sign of other serious issues
#261072 What Car Inspires You...
Posted by Steelie600 on 18 May 2013 - 08:07 PM
Postman pats Van
Dont believe me wait till ive finished the paintwork!! LOL
#260977 Fastest Quickest Acceleration 50-70Mph In Top 5.0 Seconds Mondeo Vs Supercars...
Posted by Steelie600 on 18 May 2013 - 02:30 PM
Ive got a target now for my Vans performance LOL.
Surprised at some of the figures from more "sporting" offerings
#260817 Rear Skirt Grrrr
Posted by Steelie600 on 17 May 2013 - 05:04 PM
its ebay for ya!!
I race RC cars and you can guarantee a second hand engine on ebay has "only seen a gallon of fuel" when infact its run for two seasons and is baggy as a wizards sleeve. Hence the term "Ebay Gallon"
Never take anything as face value on there and treat everyone with suspicion
#260809 The Great Royal Nail Rebuild Thread
Posted by Steelie600 on 17 May 2013 - 04:26 PM
Righto piccy time!! just to recap, ive welded plates on all the holes. Seam sealed all the joints, also seam sealed the joints where the cargo bay panels join to stop water ingress (not done at factory) I've fully undersealed the cargo area and rear crossmember.
Also ive wire brushed all the rust from inside the cab and engine bay, treated the rust with rust remover, and zinc primed the problem sots inside the cab and under the front arches. Engine bay has had first coat of Rosso red. Not bothered priming and painting under here as its generally red anyway, so just a light tickle with the emery paper and straight on with the colour. I will give it another coat tomorrow, and then when I shoot the body itll get another coat. So will be a nice deep glossy red.
Heres the pics
#260653 K&n Air Filter
Posted by Steelie600 on 16 May 2013 - 08:23 PM
Ive just seen the perfect car for todays descerning chav scum
#260628 K&n Air Filter
Posted by Steelie600 on 16 May 2013 - 07:02 PM
Quoting main dealer price pal!
My personal opinion is that anyone that fits a high flow cone filter to their car unless its forced induction and running silly amounts of boost, need a full frontal lobotomy.
No matter how many times Ive told and proven to people that they are shat, theres always some knob in a burberry cap that thinks otherwise.
#260354 How To Install A Conical Air Filter To A Zetec S?
Posted by Steelie600 on 15 May 2013 - 08:58 PM
scorpion are probably the best pound for pound back box. A nice 2 1/2" rolled tail pipe will look and sound the nuts on a fizzy. Anything bigger and itll just look daft and have the rozzers hunting you down. Subtlety is the key word for young lads in fast cars. But the scorp do sound nice when nailing it but are plenty quiet should you need to blend in (if you know what I mean)
with a filter and back box your prolly looking at a 8-12bhp increase just by bolting them on due to the engine being more efficient. Youll also find its better on fuel too!
#260315 How To Install A Conical Air Filter To A Zetec S?
Posted by Steelie600 on 15 May 2013 - 07:38 PM
Short and simple answer dont bother. You will get less power, less mpg and devalue your car. Because 1 look at a cane filter and people with think its been chavved.
My advise as a professional mechanic AND motorsports engine tuner, get a high capacity panel filter to replace the standard filter. Youll get real gains and not just noise and chav appeal
#259010 Worth Buying Genuine Glow Plugs?
Posted by Steelie600 on 10 May 2013 - 05:14 PM
OE ford/Motorcraft or NGK are what I always recommend to my customers. You wont get any performance increase, but the best for reliability are Ford/Motorcraft or NGK
(Motorcraft is Fords after market parts company)
#258963 1988 Granada Scorpio 4X4
Posted by Steelie600 on 10 May 2013 - 02:34 PM
I'm new to this and would like your comments on the car that I now own. 1988 Granada Scorpio 4x4, full manufacturers RS body skirting and RS suspension, 18,000 genuine miles from new, black body with full tan leather interior. I have all of the MOTs as it was owned by my Dad from 6 months old. Has been garaged for years, hence low mileage. Anyone know how I find out how many of these were made and any idea of the value?
Hi dean, I know the beast yer talking about, Ive worked on a few back in the day. Most were cop cars I believe, but a small amount released to the public.
Lets see some pics of the beauty, and I can help with any mechanical issues you have. Info like above Give Ford themselves a ring they will have all the documents at the factory. Im presuming yours will be a German built car, as most Granny/scorpios were, but ford uk will be able to get you the info
