Member Since 02 May 2013
Offline Last Active Apr 14 2015 03:11 PM
Airbag Light Continues Flashing 4 Times, Pre-Tensioners Reset
11 April 2015 - 11:30 PM
Hi everyone,
I am wondering if anyone has any further ideas on this one, before I take the bulb out altogether.
I have tried several times unplugging the yellow connectors and plugging them back in, to no avail.
(Waited for several minutes each time with ignition off.) Also tried disconnecting the battery, this did not work either.
Many thanks!
Co Emissions High: Overfuelling?
15 May 2014 - 12:08 AM
I have just had a new cat fitted to my Ford Escort (1995, 1.4 petrol) and the CO emissions reading is still high. I wonder what the chances are that the engine coolant temperature sensor is faulty. I recently
replaced the lambda sensor, and lambda readings are OK.
Many thanks!
