mixmasterlooney
Member Since 04 May 2013
Online Last Active Today, 07:06 AM
In Topic: Drl Positioning
25 June 2015 - 07:54 PM
Then you don't need to cut your bumper to put it above the fogs, maybe a small hole behind the DRL to hide the cables
In Topic: Mondeo 62 Echo Boost Stop/start Malfunction Of Stop/start
24 June 2015 - 08:54 PM
Yup I had my clutch on my focus replaced around 25k miles or something like that IIRC, it was making a whooping grinding sound, i had a nightmare of a time with Ford and my warranty company in the end cost came out of my pocket Yours is petrol though so may be different, mine is a 2010 Focus 1.6 TDCI
24 June 2015 - 08:51 PM
:D Whenever your ready I'm game. BTW can you link me to the DRL's I'm curious how they are mounted
24 June 2015 - 07:49 PM
It's not so bad TBH I done the holes on my bumper for the washer jets and it was even close to anything to get a clear measurement lol, the good thing is you've for your fog lights to use as a reference point. You can mask off the area and draw some vertical lines using a level and then measure up from the top of your fog lights and do the same on the other side, doesn't matter too much where it ends up as long as they match up.
It also depends on the DRL design too if they are surface mounted or designed to be flush, if you ever consider it again I'd be willing to help :D
24 June 2015 - 04:53 PM
James if your brave enough mate you could slice the bumper in the same position as face lift mondeo DRL extra work but with some masking tape and numerous triple check I'm sure you could get it maybe an inch above the fog lights
