Member Since 06 May 2013
Offline Last Active Jul 31 2013 05:09 PM
In Topic: Squeaky Brakes.
31 July 2013 - 04:57 PM
ok thank you my dad said dust but its been happening a while now , i thought theyd check the brakes anyways i though it may have been the pads need changing or something. i think the fact they told me my suspension had gone and the price it was goin to cost to fix it that i got side tracked and forgot to mention it.
In Topic: Abs System Broked
27 May 2013 - 09:40 PM
ill check them out , a few people have said to repair them , wats the guarentee tho for it to be actually fixed ?im guessing if its a common problem they will of done loads.
and does any1 know if all ford 2006 ford kas will have the same unit  and the same serial numbers ive heard 2004-2008 models do but i dont believe everything i read on the net.
26 May 2013 - 01:26 PM
well its deffo the abs full thing thats gone
now just need to find the part , i gt told not all kas have abs though and also has my car been a slightly older modle it would be easier to get the parts,i wouldnt mind really i just done like that the speedo doesnt work , esp when ur sat nav always falls off .
24 May 2013 - 03:00 PM
just a quick update if any1 still cares or wishes to help
finally took the car in , they cant pick up a problem with ABS , hes took it to another garage and an auto elelctrican who couldnt find a problem either checked 4fsues n alternator which are all fine, hes suggested i take it to ford (at 85 an hour itd be cheaper to buy a new car) however said the code keeps coming uo abouyt the throttle so gonna fix the sensor for that to take the managemnt light of hopefully (not sure if this will help the speedo issue like my bf tinks bt he knows nothing)
so im guessing like alot of other 2006 modles that the whole units gone bye bye :(
12 May 2013 - 11:03 PM
im guessing if 2 systems have failed to pick up the abs problem , and alot of other 2006 fords have had these symtoms , i have a very expensive repair on my hands :(
