lcjohnny
Member Since 11 May 2013
Offline Last Active Oct 26 2014 08:50 AM
In Topic: Focus Locks Problem With Audio Upgrade!
11 May 2013 - 04:04 PM
Ok good point about the number of ECU's in a car I was thinking motorcycle-simple :huh: - there is freeware for writing control instructions to the (single) ECU on motorcycles
I did reconnect the battery as the locks popping every 20 seconds flattened it but the symptoms did not change: the alarm and locks were still mad after that
So I will enquire at the Henry Ford factor for the appropriate patch cable to replace my aftermarket one - and ask BEATs for their fitting instructions as I appear to have lost the originals :\
11 May 2013 - 03:48 PM
It turns on and off with the ignition ok.
3 questions
1) do i need to command the ecu not to look for a radio on the can leads?
2) Is there a recommended suppier of patch leads
3) is it necessary to connect to the steering column remote controls
11 May 2013 - 03:20 PM
Hi Tomtom 70
My lead only has terminal blades in A1-A8 then A12-A16 so 9,10,11 are not connected
and none in B or C
I did not get a patch lead for the steering wheel remote
There is no branding on this lead but I could take a picture if that helps?
