linsphilg
Member Since 12 May 2013
Offline Last Active Jul 23 2013 04:48 PM
Fiesta Glove Compartment Cut Out For 3.5Mm Socket
12 May 2013 - 11:36 AM
Attached File  DSCF9286.JPG   151.86KB   21 downloadsJust had an aux. lead fitted to back of audio system, the end of the cable has a black round about 2.0 cm diameter socket with hole in middle for the 3.5mm jack. At moment the cable is loose in the glove compartment. I cannot see how it will fit into the larger square cut out in the glove compartment ?. Is there an adaptor plate missing ?.  If this square cut out is not for the 3.5mm plug, what is it for ?.
Thanks,  Phil.
Apparently the square hole is designed for a passenger airbag deactivation switch.
I made the round female socket fit in the larger the square hole, used an old credit card, drilled and cut a 22mm hole in half the credit card and cut to fit as a backplate. Then cut a 20mm hole in the other half of the credit card and cut to fit as a front plate. Front plate took a bit of persuading over the front lip of the aux. socket. All OK so far.  I did not feel like drilling another hole near the gear stick.
Thanks for all help and advice.  Phil.
