Member Since 13 May 2013
Offline Last Active Sep 09 2013 08:50 PM
#277456 After Market Stereo...helppp!
Posted by trikidy on 25 July 2013 - 03:03 PM
Hi thanks, yeah if you look at the link to the ebay item it seems to have a wiring harness, cage and fascia- so with it I guess it would all fit?
#276999 Fitting Led's In The Boot- Example On Mk 6.5
Posted by trikidy on 23 July 2013 - 04:05 PM
Just pull it out. Best to do if you climb over back seats as the stock one does get very hot!
Take your pick of colour!
#271729 Panther Black St-2
Posted by trikidy on 30 June 2013 - 05:32 PM
Ha well it's all about who you know!
Enjoy it, looks an awesome car
#271263 Decent Illuminated Gear Knob?
Posted by trikidy on 28 June 2013 - 05:57 PM
Just fitted mine! :D
Initally grounded it to my LED wire, but then it would only work when the LED's are on, strange as I thought the ground would just ground it, ended up doing like you and wrapping around a nut :)
#268460 Fitting Led's In The Boot- Example On Mk 6.5
Posted by trikidy on 17 June 2013 - 01:27 PM
I have now fitted my footwell lights...tutorial to follow!
#267738 Fitting Led's In The Boot- Example On Mk 6.5
Posted by trikidy on 14 June 2013 - 09:38 AM
Thanks guys, give it a go!
Hardest bit is cutting and crimping the original light wire- its only hard because its awkward to get at!
#267702 Guide To Converting Stock Climate Controls To Custom Set
Posted by trikidy on 14 June 2013 - 12:09 AM
yeah I will check tomorrow, but that measurement seems to be between 350-400mm
#267592 How To Fit Lights In The Footwell Of My Lovely Car?
Posted by trikidy on 13 June 2013 - 05:03 PM
Here you go mate
#267591 Fitting Led's In The Boot- Example On Mk 6.5
Posted by trikidy on 13 June 2013 - 05:02 PM
Hello! This is me trying to explain how I fitted LED's in my boot. The total price was £28.13, but you will be left with plenty of supplies to do this again, you will have loads of crimp butts, cable and a tool. So any future jobs will only require the LED's (£6.60).
First things you will need are the actual LED's, for mine I used 4 but you could use less or more, the ones I used are from ebay:
They come in 30cm strips with sticky backs, ideal for this.
Next you will need wire, speaker wire I am told is the best and for mine I used this:
You won't need 20M, but it works up about the same price- plus you have spare to do the footwells!
To connect the wires and the LED's you will need crimp butts and a crimper, again crimps I used
Think I used 6 in total, but for the price I can't complain. Then for the crimping tool, I bought this:
It has a wire cutter too which you will need and is a very good product.
Once you have all the equipment you can begin!
I will try and describe what I did and then supply photos, basically we will be using the live and negative from the factory fitted light to power our neons. In order to get to the wiring of the light you have to undo 3 screws, then pull the plastic away- it won't come fully away but you don't need it to, just wiggle it! Once you have access to the light wiring, which is quite simply the two wires going into the bulb, you need to cut them both- try and cut it so you leave enough wiring each side, the middle is best. Then strip the ends of the wire you have just cut IE remove the insulation.
To test which wire is negative and positive just put the end of the neon wiring to one wire, on the neons the wire with blue on is positive, the other is negative- for the speaker wiring that I have linked to it is red for positive and black negative. Once you have worked out which is positive and which is negative it is time to wire it up!
Get the end of the light that you have just cut and twist the ends around the speaker wire, for example wrap the red speaker wire around the positive wire from the bulb (pos and pos), then the black with the negative wire from the bulb.Then you need to crimp it so they dont budge, basically put one end in the crimp and crush the crimp with the tool, make sure it is tight. Once this is done re attach the other side with the negative and positive that the light was originally connected to and you have done the hardest bit!
After this I roughly worked out how much wire I would need to get to the boot latch knob bit and cut the wire, then I pushed it behind the plastic fascia bits in the boot and it came out behind this metal beam next to the latch. As you did with the crimping before, you will now need to crimp the neons with the speaker wire, I used three here so get 3 neons, strip the wire and wrap the positive of each (blueish) with the positive of a fresh piece of speaker wire (red) and then crimp this in one end of a slightly bigger crimp( I used a blue crimp), do the same with the neg (clear on neon and black speaker wire). Then simply connect the crimp with the wire you have put down behind the fascia and they should work!
The fresh piece of speaker wire you have wired I used for the final neon, again over estimate how much wire you will need and cut and strip it, then try and thread it through the metal bit so it is hidden. Once it is near where you want it crimp the last neon to it, posi to posi, neg to ned and you are done!
I sat in my boot to do this as they are not actually on when the boot is closed, then opened it as I went along to test it. Once they are all working simple peel the back of and stick it where you want them in the car.
Find your light and remove the parcel shelf, I also pushed the seats down to make life easier.
Pull the cover off the light and remove the light from the plastic cover thing.
Here are the three screws you need to undo, then simply pull it towards you and it should come lose. I couldnt get the side nearest the rear chairs to come off but you don't need it to, you should be able to get to the light now and the wiring.
This may look complicated but it is not. The speaker wire is red and black, but black wont show up so I put it in red and white. This is where I pushed the wire behind.The yellow square is the crimp and the yellow wires coming from it are the neon wires. at the far one I have done the neon wiring in red and white for some reason.
Tuck the wiring up in the metal frame and under the plastic to keep it hidden.
Here you can see the metal frame thing I am on about, the wires sit nicely hidden in here and this is what you post the wires down to get them across one side to the other.
I know this isn't the best but hopefully it gives you an idea of how to do it!
Any questions feel free and I will see if I can help!
#267536 How To Fit Lights In The Footwell Of My Lovely Car?
Posted by trikidy on 13 June 2013 - 01:05 PM
Update: I have fitted some LED's in the boot of my car, this was mainly to practice crimping and doing it.
Went really well, will get some pics up when it is dark.
The footwells will have to wait until I get some more LED's, next week probably!
#265951 How To Install A Conical Air Filter To A Zetec S?
Posted by trikidy on 07 June 2013 - 10:19 AM
Just an update,  I went for this one, came 2 days after!
Has made a huge difference to the sound of my car:
#264348 Flip Key.
Posted by trikidy on 31 May 2013 - 07:15 PM
There is a guy whose number I found on the moneysavingforums, he is a specialist at cutting Ford keys and is very good.
He cut me another remote locking and another spare key without central locking for £150, plus he comes to your house.
I'd ask him as the amount of kit he has is amazing, his number is 07860234660
#263756 Cheaper Place For Interior Bits?
Posted by trikidy on 29 May 2013 - 02:07 PM
Hello again, found a couple of things on ebay that I haven't seen on sale anywhere else!
Looked about the web and ford sites but nothing, wondered if anyone on here knows of a sight or a place!
The items are handbrake cover and door handle cover, links below!
Thanks guys!
#263750 How To Install A Conical Air Filter To A Zetec S?
Posted by trikidy on 29 May 2013 - 01:35 PM
Okay thanks mate!
Decisions, decisions...
#263474 What Is This Reflector Type Thing In My Headlight And Where Can I Get Another?
Posted by trikidy on 28 May 2013 - 01:41 PM
Just to finish this topic, the lights are the same colour. One is better quality that is all!
Ended up getting it for £70 and fitted!
Thanks for the help!
