Member Since 15 May 2013
Offline Last Active May 15 2013 07:15 PM
#260309 Fiesta Stop Start System
Posted by Cat7 on 15 May 2013 - 07:11 PM
Hi all,
Titanium X 1.0 (125) 2013
Is there anybody else having the same issue with their stop start system?
Air con - off
Climate control - off
Engine up to temperature.
No heavy current drain equipment on.
If you have the fan on its 1st setting and the temperature on the low setting, the engine refuses to cut out. If you move the temp up to 20 deg the engine will immediately cut out.
These are obviously only low current drain so why would the above prevent the engine from cutting out?
Confused, can anybody help.
