Member Since 16 May 2013
Offline Last Active May 23 2013 08:44 AM
2005 Ka Gearbox Removal
18 May 2013 - 12:24 PM
Hi, I'm intending to replace the release bearing assembly. Can the gearbox be removed without uncoupling the exhaust? The Haynes manual is unclear as to which coupling on the exhaust needs unfastening. There are two heat-shields situated above the RH driveshaft, the upper one has rusted bolts. Can the engine be canted down without having to uncouple the exhaust pipe? The car is on axle stands.
