HarryNLD
Member Since 23 May 2013
Offline Last Active May 17 2015 09:23 PM
In Topic: Fiesta Mk7.5 "battery Back Up Sounder"?
17 May 2015 - 09:11 PM
The backup battery alarm is in fact a part of the Thatcham cat. 1 alarm. It is a siren with a little battery in it. It's placed behind the right front wing.
This alarm is only fitted on the ST models, and only in the UK. In the rest of Europe it is an option (only on the ST).
I retrofitted the thatcham alarm on my Titanium X, works great, but it is a lot of work to get it done.
Picture of the siren with backup battery:
In Topic: Help Please With Sony Radio
15 April 2015 - 08:12 PM
I do remember a problem with the Focus (or Fiesta, I don't remember), that had the same symptoms.
In those cases the Bluetooth/voicecontrol module was broken. You can easily test this by removing the Bluetooth/voicecontrol module.
Here's a removal video:
15 April 2015 - 07:44 PM
No, a facelift sony isn't gonna work in a pre-facelift model.
The pre-facelift model has the old bluetooth/voicecontrol system and the facelift model the SYNC system.
You should be okay with FM, but your AUX/bluetooth/carkit system won't work anymore.
In Topic: How Can I Remove The Bottom Of The Right Seat Plastic?
10 April 2015 - 02:32 PM
1. Remove the seat adjustment knob
2. Remove the screw on the back.
3. Pull the back end out for a couple of cm's.
4. slide the hole panel forward.
And that it's.
In Topic: Fiesta Adjustable Load Floor Question
08 April 2015 - 11:02 AM
Not a problem.
