Member Since 24 May 2013
Offline Last Active Jun 04 2013 01:17 PM
05 Ford Focus Instrument Cluster
24 May 2013 - 11:14 AM
Hi All,
This is my first post here, so would like to say Hello first. I browsed this site a lot since purchasing my Ford, but never had a need to post, until now that is. So here goes.
So, I have a Ford Focus LX (05 Plate), I have been getting error codes on the dashboard showing the check engine light. This happens but when you turn of the car and re-start the error code usually clears. I however was driving to work the other day and the car cut out and rolled to a stop.
I then proceeded to try and restart the car, but nothing. The car has since been towed to the local Ford dealership who have informed me this is a fault with the Instrument Cluster and the immobiliser is therefore stopping the car from starting. The garage has quoted this work at costing in the region of £700.
This seems a lot, so I was googling and seen this is a common fault on Ford Focuses and watchdog once covered this issue and Ford were fixing the issue for around £100.
Please can you let me know if this is still the case and if there is a chance my car would fall in to the ones effected (as I am not sure which years/models have this fault)?
Also how do I go about raising this with the Ford dealership, or should I try and contact Ford head office?
Any help would be appreciated, many thanks.
