ZetecShearer1987
Member Since 24 May 2013
Offline Last Active Jan 31 2015 01:21 AM
In Topic: Air Intake Pipe Advice!!!
23 November 2014 - 08:00 PM
Hi I have still not found any solution to fixing the rough hesitant engine. Been back to ford and no faults are found so can't help me apart from change over 100 quid to check.
Erm I have also the issue now that the car doesn't idle anywhere near the correct level. Most of the time it's hovering around 1000 rpm. I'd I keep pressing the accelerator it eventually drops down to the correct level. This is when the car is warm. Any final ideas as I'm probably gonna get rid of the car as it's been nothing but trouble.
18 October 2014 - 12:58 PM
Thanks I've got some carb cleaner. Where's best place to spray and safest place where these leaks normally occur
17 October 2014 - 09:05 PM
I'm gonna try and check for a vacuum leak as when ford refitted the breather pipe the car felt really good for a short while. What's the best way to do this as I'm gonna use a spray water bottle. Where's best to spray and try to get the car to stumble. Would it really be a fuel pump issue as it always starts first time plus engine roughness is very intermittent. Feels like the engine looses compression when it get the symptoms. As when ford refitted the breather pipe all the power plant smoothness came back.
15 October 2014 - 07:00 PM
And my car does this whatever fuel is in the tank full or low still surges and hesitates
15 October 2014 - 06:59 PM
My car doesn't have a maf sensor instead it uses a map and the pcm to work out the air mixture. My car does have esp so I will turn it off tonight to see if it makes a difference. Hopefully. Only problem is what happens if it does.
