Member Since 29 May 2013
Offline Last Active Sep 18 2014 02:29 PM
What Would Happen If..
13 September 2014 - 04:56 PM
When fitting a new 'o' ring seal on the injector leak off pipe, i managed to loose the r clip for the small black connector. Anyway, i can't fit a new one as there's wires and pipes all over, i've tried, but lost the new clip also!... So, what would happen if i unplug the following? I wouldn't loose the injector codes and have to reprogram would i?
1.8 Tdci.. Where Is..?
02 September 2014 - 06:36 PM
The Throttle Position Sensor on the above engine (Mk2.5 Focus)? I've googled and searched but can't really find any info. Cheers.
Fuel Leak From Here..
29 August 2014 - 02:30 PM
I've noticed that connector on this braided pipe is damp where the rest are bone dry and to be honest, i'm not entirely sure what i'm looking at..
Can someone tell me what this pipe is (i'm guessing leak off pipe? and if it's easy to fix?
Rattle Rattle!
06 October 2013 - 02:53 PM
1/ Clutch pedal sticking on travel upwards from floor
2/ Damp patch around bell housing
3/ A metallic, sporadic intermittent rattle when in neutral which is also now noticeable when accelerating in low gears (undetermined whether this is clutch plate and/or DMF)
4/ Difficult to get into 1st, 2nd and 3rd
5/ Hesitating (intermittent) at 50-60mph
This is the result of a recent diagnosis I've had done on a 4yr old TDCI (1.8). It's going into the dealers I bought it from tomorrow for repairs, but I wondered what you thought the new parts list will include?
