Tezza
Member Since 10 Jun 2013
Offline Last Active Mar 26 2015 07:13 PM
#443802 Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
Posted by Tezza on 11 January 2015 - 03:18 PM
I would go back to 509 and see if the function comes back
#436064 2015 Ford Mondeo
Posted by Tezza on 11 December 2014 - 09:58 PM
We had a titanium estate delivered yesterday :)  its very nice
#418682 Anyone Retrofitted Power Fold Mirrors?
Posted by Tezza on 12 October 2014 - 06:49 PM
Working for ford over 23 years it does not matter if it's left hand drive or right hand drive :)
As for the relay your talking about that only applies to the mk2 pre facelift and does not the facelift
Trust me if you have a facelift just fit the mirrors and the new mirror/ window switch and add a wire from the mirror to the door module pin 14 blue connector and all will work as I have done this to mine and a few others and it works perfect :)
Yes the UCDS is like the ELM but better as you can do the same as ELM but more :) cost more but worth every penny
#416397 Fiesta St-2 St-3 Open Close Windows With Key
Posted by Tezza on 05 October 2014 - 08:18 AM
If you can open and close the windows without holding the window switch up/down here's what you do
To open the windows press the unlock button on the remote once the press it again and hold it down (few seconds and the windows open)
To close the windows press the lock button on the remote twice the press it again and hold it down (few seconds and the windows close )
#404294 Key Fob
Posted by Tezza on 01 September 2014 - 08:16 PM
When your in the programming mode you have to program both remotes at the same time  (press and button on the remote then on the old one)
#403330 Travel Pilot Nx Upgrade
Posted by Tezza on 30 August 2014 - 02:41 PM
David
If you have climate control then its a straight forward job as all you would need is the headunit and the climate control module and a different dash fascia
Once you have all the bits it will take you under a hour to change as its all plug and play
#367016 Deflation Detection System
Posted by Tezza on 22 May 2014 - 08:13 PM
This is how the tire pressure monitoring system (TPMS) works on the fiesta
https://app.box.com/...tw0vnk3iwffk0je
#350723 Dvd Colour Sat Nav (2006) Bluetooth Gone!
Posted by Tezza on 04 April 2014 - 12:04 PM
Working at fords I do have a new one in a box that we used as a tester module
Not used it for awhile so it you want it You can have it for £50 posted
#350713 Dvd Colour Sat Nav (2006) Bluetooth Gone!
Posted by Tezza on 04 April 2014 - 11:23 AM
Yes that will work as it's listed for the s max from 2006 to 2008
#312172 Anyone Retrofitted Power Fold Mirrors?
Posted by Tezza on 15 December 2013 - 08:35 PM
Well done, how did you acheive this? I'm hoping to do this to the wifes' Titanium though you're the first I've heard manage it.
There has been a loads of people that have had this done is just the matter of getting the correct programme and the correct interface to do it as the EML is not capable of doing this yet
If anyone don't have the door modules to fit the folding mirrors the best place to get them is ebay and the looms from fords are £50 each
So you will also be getting one touch up/down also with the power folding mirrors
If anyone's interested I can get a set of the power folding mirrors with puddle lamps for £210 posted for the pair :)
#308530 Touchscreen Navigation System (Sd Card)
Posted by Tezza on 03 December 2013 - 06:57 PM
Try this
https://app.box.com/...xzmav35skol5ue8
#307737 Paul Walker- Star Of Fast & Furious Films Dies.
Posted by Tezza on 01 December 2013 - 11:11 AM
RIP Paul 2Fast2Soon. :(
http://www.bbc.co.uk...anada-25173331
#301934 Smax 2011 Navigation Issue
Posted by Tezza on 03 November 2013 - 04:04 PM
I work for a ford dealer and we charge £25.00 to get the satnav codes
The dealer would need all the numbers of the side of the head unit to get the code, and if its made in Germany they will have to fax off the code
The supplying dealer should have the code on record so ring the dealer that first stamped your service book as they may let you have it for free
#292589 Retrofit Auto Lights And Wipers
Posted by Tezza on 25 September 2013 - 06:22 PM
Well done :)
Apart from the power fold mirrors this is the best mod I did even tho it cost me £400 to complete lol
#289610 Sat Nav Sd Card
Posted by Tezza on 11 September 2013 - 08:42 PM
When the offer end's these are the finis numbers you will need to order for the lastest maps
Ford NX 1829510 @ £119.00 inc vat
Ford MFD 1829529 @ £119.00
Ford MCA 1829531 @ £119.00
Ford FX 1829521 @ £119.00
