Gazamoato
Member Since 11 Jun 2013
Offline Last Active Jun 12 2013 09:04 PM
In Topic: Mk2 Facelift - Retrofitting Bi Xenon Headlights
12 June 2013 - 01:17 PM
Julz- in order to get the xenons to work you need an extra earth wire in port 8 on the plug on your wiring loom and it will work. I fitted them to mine and had to do this little mod to get them lighting.
Hope this helps
Hi how do you go about putting the earth wire on and where from?
12 June 2013 - 11:57 AM
Yeah I've had them in but no working xenon. So just the wiring I'm struggling with at the moment :( I'm gonna go out to the car and see what happens. ( ill keep my I pad on if anyone has any key advise ) :)
12 June 2013 - 11:26 AM
Oh yeah an st my bad :(
12 June 2013 - 07:31 AM
Hi guys, I know this is an old topic now but could do with point in the right direction.
So I've bought a set of xenons off a RS to put on my 56 plate tdci my connector has 7 pins the xenons have 10
Is it still a case of adding an additional earth wire or has it evolved any ? Would any fuses need to be upgraded
If just the case of adding the earth wire would appreciate it if some one could explain to me in lay men's terms how to go about it. As I don't want to damage anything and leave myself with no lights
Gaz
