Morgie
Member Since 13 Jun 2013
Offline Last Active Today, 01:00 AM
In Topic: Focus More 1 Leak
Today, 12:42 AM
Pollen filter under scuttle board not sealed right it has a bead of bitumen type sealer arounf the edge ford dealers don't seem to fit them correctly.  Or drain holes blocked in roof gutters clean them with a piece of thin wire.
In Topic: Front Right Rattle 2004 1.6 Focus
17 April 2014 - 12:29 AM
here are a few suggestions bottom ball joint/wishbone main culprit / this would be more of a knocking thou. top strut mount, rear engine mount.  have a check of your spring too I have replace 2 on mine normally snap near the bottom cup end stop. a rattle could be exhaust heat shield loose.  best of luck
