jayhus123
Member Since 15 Jun 2013
Offline Last Active Feb 26 2015 08:52 PM
In Topic: Hi, Does Anyone Know Where The Reverse Light Switch Is Located On A Ford S Ma...
09 November 2013 - 01:26 PM
Ok it seems the clicking only occurs whilst going into biting and changing gears, something to do with clutch also when taking into reverse gear you can hear a click.
sent from S3 using app
08 November 2013 - 11:28 AM
There seem to be no error codes on the system. Over the weekend I will get the fuse box out and reinsert all the fuses. Its a bot of astruggle to get to as its under the glove compartment on the passenger side.
08 November 2013 - 10:18 AM
Reverse stays on regardless of putting into reverse. Start moving and it flickers randomly. Had to take the lights off yesterday as it got dangerous for other road users.
07 November 2013 - 11:47 PM
Ok....I have checked the battery power on the on board system and its at 13.5 whilst the engine is running. Is that where it should be? With the reverse light...now it stays on when the key is turned once without the engine running. :huh:
07 November 2013 - 04:00 PM
Would the battery power affect the reverse light madness???
