owlass
Member Since 19 Jun 2013
Offline Last Active Jun 21 2013 05:19 PM
In Topic: 2011 Plate S Max Low Fuel ?? :s
19 June 2013 - 05:56 PM
no not a smell atall that i can notice meself, wudnt even notice ther was a prob with the car apart frm the fact the eml came on and gave that fault code so want to get it sorted before it gets any worse
19 June 2013 - 05:50 PM
ok ill try cleanin the fuel filter an fuel lines tmra, u think checkin the fuel pressure sensor mite b the prob? i just want to get all the maybe's so i can check them all at once. i got autodata to check what the reading should b for the sensor
19 June 2013 - 05:25 PM
ill have a try of that tomorrow, any other ideas apart from the fuel pump just incase, if it is low fuel pressure it is before the fuel pump if i am correct not after yes?
19 June 2013 - 05:13 PM
were is the fuel pump located on this car, is it possible to clean the pump out, if so how do i do it? :D
19 June 2013 - 05:10 PM
maybe a pierced hole in the fuel line before the pump, that another reason i am thinking?
