Member Since 28 Jun 2013
Offline Last Active Jul 04 2013 04:51 PM
In Topic: Help ! Mondeo Mk3
04 July 2013 - 04:51 PM
Is the car turning over? If so you could just have a massive air block! All you would need to do is as your turning the engine over crack number 3 injector (fuel pipe) and keep doing it until she starts it may take quite a while :/ the problem is the people at ford thought it would be a great idea to not fit a fuel primer on the MK3 its genious :@if not take the fuel filter of fill it full of redex and try then
In Topic: Mk3 Tdci Replacement Dmf Help
01 July 2013 - 06:19 AM
Could just be an injector leaking off or not pressurising up?
30 June 2013 - 04:22 PM
It takes me around 4 hours with a 4 post ramp so a lot longer on the floor
In Topic: Mondeo Tdci Injectors Question
29 June 2013 - 07:35 PM
If there were no filings you should be ok but when a pump goes usually you replace the tank fuel lines and injectors but you might be lucky
In Topic: Mondeo Tdci Start Up Issues
29 June 2013 - 05:37 PM
It will definatley be the injectors! I've had like 10 mondeos do it! The only problem is is finding the injector that is leaking and when you do if you don't have a virginalised fuel pump you may need them coding. You will find that it will knock its !Removed! of in the morning and then run fine!
